Forum: Old versions
Topic: Maximum Track Length That Can Be Loaded?
I bought the hercules dj console mk1 when it was first released and apart from the expected teething problems which you get with any new release, all seemed to be running fine. I have recently installed this on to a new pc and now it will not load any tracks that are longer than 10minutes in length. No track images appear in the cue/play window and when i try to cue up, the playing track sticks an repeats a second long length over and over until I control/alt/delete. Is this a limitation with virtual dj that it cannot load track that are longer than 10minutes in length? The other problem is that there is now very noticeable interference noise when using VDJ and use the Console controls, its like a clicking sound. Please can you help? I was thinking of buying the latest full version of VDJ but as a number of other users have suggested they experience the same problems as me then I would really appreciate your help before I make any decision to buy. Thank you.
geposted Mon 07 May 07 @ 1:31 am
Hi VinylJunkie...welcome to VDJ...(",)
If you go into Config and set your max load to higher than what it currently is, you should find that tracks of longer than 10 minutes will load...although I'm not sure if there is a limitation on the demo version for what this can go up to.
As for the clicking sound, sorry, but I can offer no advice on this as I'm not a HDJC user.
One thing you will undoubtedly be asked is what are the specs of the machine you are using? Posting them nice and early in the thread could assist in identifying any potential problems.
Hope you get it sorted.
Cheers...and keep spinnin'...(",)
P
Yes, increase Max Load value to 15 or 20 minutes and it will load your tracks. The demo is the same as Pro, just for 20 days.
About clicking, it can be many things, try to disable safemode and enable Overclock or lower performance slide to the left.
