Forum: Old versions
Topic: Global Database
This feature isn't reliable. During the play back the program just shuts down and then restarts. No good for whe your in a live situation.
This happens on more than just one of my laptops. I'm actually doing one of the VP's from Napsters wedding in June
geposted Mon 07 May 07 @ 8:14 am
Explain a little better what is the problem, which file U are using and can you reproduce the bug?
I don't think the Global Database option is very reliable either. It does some quirky stuff to VDJ. After using GD I cannot shut down VDJ. Sometimes it will just shut VDJ down all together, especially while trying to download a song.
Yeah it's never worked for me either... safer just to run Napster in the background, and have the downloaded songs directory tagged as a favourite in VDJ...
Agreed with Sherz!! Thats the way I do it in a bind, but I like to run VDJ with the bare minimum running in the background.
having problems also....with napster freezing vdj on load
