Forum: Old versions
Topic: Maximizing performance
I posted this in the tip areas, but
When loggin in , Hold the Shift key. This will not startup items in your login items..
This can help with minimizing processes that run for max performance.
geposted Wed 09 May 07 @ 5:10 pm
jchiar, Is there anything I can do to get the font to show up in the search field? I understand this is the new release and I have told to be patient, which I am, but it only goes so far. This has been out for over a month out and have seen NO indications that this is being fixed. I really want to use my software, but I can't because of this.
You mean you still cant see things in the browser? Thats strange. I havent heard of this one. The latest build fixes the browser aka FONT BUG..
Care to post a screen shot?
I can see the browser and everything. I cannot type anything in the search field.
ok, i got cha. does it crash when you try to search? And does it search correct but you just dont see what you are typing?
Doesn't crash. It doesn't type or search at all.
Speed, i know its a bummer and I wish i could help you with the issue. I dont have this issue so i cant even suggest a work around.
Keep faith in the devs...
THey are probably like mad lab rats trying to work out the issues.
After all, its tied to a Numark product and I am sure somewhere, someone has more pressure than you have on getting it to work..
BTW Have you posted this bug in the MAC bug forum?
The dev staff is already aware of this problem
Cel,
Thanks for the feedback on this..
