Could someone please create a Mapper for Numark Total Control..
It didn’t come with a Mapper.. I even installed Cue to see if they put it in there Control Device folder but nothing..
geposted Tue 15 May 07 @ 7:29 pm
i dont think that you need a mapper for make it work.
just enable it on remote control settings.
they have add total control in v 4.3
geposted Tue 15 May 07 @ 10:02 pm
yes it work fine but I'd like to change one or to buttons
geposted Tue 15 May 07 @ 11:00 pm
@ paulettecerra
does the scratch button turn the jogs to scratch dials and back to jog dials?
geposted Tue 15 May 07 @ 11:48 pm
yes you can with the push of a button.. The buttons are nice
geposted Tue 15 May 07 @ 11:52 pm
The current SDK does not provide an interface for writing a custom mapper for the Total Control unit. However, since the device is a MIDI device, you may be able to uncheck the controller's native setup option and check the MIDI option and program the different functions that way. ** NOTE you would have to associate all of the buttons, faders and alike in the MIDI config section. **
I don't have the unit, so I am only basing my suggestion on the fact that it is a MIDI device.
geposted Wed 16 May 07 @ 12:24 am
i agree with cstol it should work like that :)
geposted Wed 16 May 07 @ 10:59 am
rest assured they will have a mapper soon
geposted Thu 17 May 07 @ 1:41 am
Can't build what doesn't exist. As I said, it's a MIDI device if you what to customize the controller you will need to use the MIDI config in the Remote Control panel. There is your custom mapper.
geposted Thu 17 May 07 @ 1:45 am
@cstoll
Currently yes you don't have the SDK to make it but it doesn't mean that it's not possible. We just need to add the parameters in the SDK.
geposted Thu 17 May 07 @ 1:53 am
:~) Never said impossible. Just want people to know that there is a way to customize the controller now and not to wait on a specialized mapper interface. Since the comment was made about 'soon' :~)
geposted Thu 17 May 07 @ 2:11 am
Out of curiosity - what would you want to change, anyway?
geposted Thu 17 May 07 @ 6:12 am
I would add a "Bump" or "Nudge" for beat matching. The unit does not come with a native nudge feature.
geposted Thu 17 May 07 @ 10:32 pm
I always use the jogwheels for that, I'm ok not having it. I should have mine here tomorrow for testing and support ;)
geposted Thu 17 May 07 @ 10:57 pm
exactly, jogs are way better for beat matching, unless you grew up with bend buttons and you cant get used to jogs???
geposted Thu 17 May 07 @ 11:01 pm
I agree but to be able to change the resistance in the jog wheel to one feel..
I think everything is setup pretty well.. A couple of buttons to presetting loops would be good to..
geposted Thu 17 May 07 @ 11:41 pm
Actually I grew up with 12" LPs, where we used our fingers to either drag a TT down or speed them up (Dont aks how it is a long descrition) I like the button and leave the wheel on scratch, it helps me get to a point I am looking for faster that way.
@Paul you can go to the different cue points buy hitting the pause button more than once.
geposted Fri 18 May 07 @ 12:09 am
It would be nice if it had just a couple of additional "spare and user programmable" buttons, perhaps.
I'm thinking a simple USB keypad could come in handy for that. ;)
geposted Sat 19 May 07 @ 8:45 am
