Forum: Old versions
Topic: Every control now makes the music "jumpy"/"stutter"
Hi
VDJ has been performing absolutely brill over the last 3 months. Two nights ago I recorded a great set with no issues...
Tonight I started VDJ up and put on a track and every control that I used [e.g. cross-fader, eq, pitch, etc] made the track "jumpy"/"stutter".
I've not gone into configuration for months and not updated since March...
Has anyone experienced this?
Thanks in advance
Jon
geposted Wed 16 May 07 @ 10:06 am
do u by any chance installed other software or hardware during these 3 mth? it could be a conflict issue started to build up;)..
Try enabling Safemode and it will be good to reinstall program.
Hey There
I've not installed any software between Monday and now.
It was in safe mode.
I've re-installed [unwillingly]
This issue still exists, any other ideas out there?
Cheers
Jon
Solution: Uncheck Safe Mode
Not for sure, you should try both, Safemode and Overclock combinations, if nothing helps you should reinstall VDJ and the drivers for your sound card.
i have this problem aswell. it worked brilliantly for about 2 months but whenever i load it up now it stutters and jumps and is horrible :(. gonna try a re-install.
Do you use it with ASIO drivers?
i tried a re-install, but still the same problem. ive not made any hardware changes or major software changes. im downlaoding new drivers atm but i doubt this will help. im not using ASIO drivers.
