Forum: Old versions
Topic: Numark Cue Mac Pro - Uninstall and Reinstall
On Mac Pro running Numark Cue. I am unable to fully uninstall the program.. i've used app zapper and also deleted the atomix file from the library.
After i reinstall and try running, I get a corrupt database error.... The program will not open.
i'm totally stuck... unable to do anything.....Called numark for tech support and they recomended calling apple to delete files from the registry... i have yet to do that but was wondering, has anyone been down this road before?
Thanks !
geposted Mon 21 May 07 @ 4:24 pm
Thanks !
drag the virtual dj folder from documents to trash
empty it.
then browse to this file
Users/yourname/Library/Preferences/com.atomixproductions.virtualdj.plist
(your name means your username)
drag this file to the trash and empty.
reboot.
reinstall.
Thanks !
There is no REGISTRY on the MAC. (They must need to hire techsuppport people)
Concerning the software part, it's better to write to the VirtualDJ support which is more specialized ;-)
i haven't tried getting rid of the numark folder from documents so will try that... but already got rid of the atomix file... and two virtual vinyl .pkg files from the reciepts foder in the library. numark gave me a program called deinstaller and didn't really tell me how to use it.. it looks dangerous... so won't attempt
i did however create a new user account on the computer.. re installed and it's working.. only problem now is all my music and videos is loaded under the original user account.. and i have to figure out how to turn i t over
That above post was given originally from a TEAMER, so dont be afraid to use it:)
