Forum: Old versions
Topic: Skyfxl, Can I use a shell swapper?
Skyfxl,
I read your blog about making it so that Virtual DJ loads instead of the Explorer Shell. Is it possible to use a shell swapper so you choose which shell you want to load?
DJ Digital
geposted Wed 23 May 07 @ 1:52 pm
Try creating different user accounts and then tweak each one to use what you want. You might have a 'Music' or 'DJ' user account that opens in VDJ shell and then have an "Administrator" account that opens everything as normal.
Possibly worth a try.
Cheers...and keep spinnin'...(",)
P
sorry for not replying fast
i have been in paris
if you make two acounts such as main and one called dj and then login to "dj"
use the section about the local user
this applies it to just this acount
so when you log into the other its normal :)
