Forum: Old versions
Topic: Audio, but No Video
DJ ELPRO InfinityMember since 2005
Hi. Running XP on laptop. I am trying to play music videos, divx files, in VDJ, but all I get is the title of the song and a black background. I have installed the divx codec and added the divx file extension and set windows media player as the decoder. Am I overlooking something?
geposted Mon 28 May 07 @ 6:46 pm
sbangsPRO InfinityMember since 2004
what is your video card spec?
geposted Tue 29 May 07 @ 12:45 am
djcelPRO InfinityModeratorMember since 2004
you can use the divx extension with the "video decoder". It works very well and i use it a lot ;-)
Just verify that you use the hardware acceleration
geposted Tue 29 May 07 @ 3:12 pm
My question now is:
How many and which extensions will function with the "video decoder",
AND which extensions need a separate codec into windows media player?
geposted Tue 29 May 07 @ 6:01 pm
