Is it possible to connect my Hercules mk2 console to a external mixer, but still use the console crossfader and controls to run VDJ.
geposted Wed 30 May 07 @ 2:00 am
Yep, just use outputs 1 & 2, the will act as left and right out of the MKII. This will give you the final mix in stereo mode. If you select 'use external mixer' in the sound config you will need both sets of outputs. This will give you a separate stereo signal from each deck. Someone may correct me, but I could swear that when I used the MKII through my external that all the controls, including the crossfader of the MKII, still worked.
geposted Wed 30 May 07 @ 5:33 am
Thanks for that, I don't want to have to change anything in my sound config, as this is still quite new to me.
geposted Wed 30 May 07 @ 6:10 am
Just select "External Mixer" in MK2 settings (MK2 tray icon). You have to do it every time you load Windows.
geposted Wed 30 May 07 @ 2:58 pm
