im having trouble adding my own samples. theyre in mp3 format and i have no idea on how to add or use them.
geposted Wed 30 May 07 @ 7:26 am
Save all of them in the sample folder of your virtual dj program folder, then when you open the program, under the samples section you can load any of them onto any no. you want from 1-12 ( on your keyboard while mixing you can press f1 to f12 and it should play synchronized to whatever you are playing). Remember to put the volume at a low level first and of course memorize what sample is on what button :-) a tip for using this things is to use them sparingly and to have variety( it sucks when a dj is predictable), and they r great for going from one genre to another and/or when songs just don't match, you know like when u want to play hits that are too far apart bpm-wise.........damn that was long!
geposted Wed 30 May 07 @ 7:53 am
breath!!!!!
geposted Wed 30 May 07 @ 8:07 pm
To load your samples into the module, open it. Rt click on the sample menu tab in the bank (located across from the number), and select load. It will take you to the sample folder. You can select which sample or you want.
geposted Wed 30 May 07 @ 8:16 pm
