Forum: VirtualDJ Skins
Topic: First Skin Download :: Please Help
<---- As you can see I use Virtual Vinyl. I am currently running the Windows version of VV on my Macbook Pro with Windows XP and Bootcamp. I plan on running the Windows version until the the Mac version is up to par on the video side.
I have so far had success in downloading all of the Plugins but cannot for some reason get any skins to work. After I download and run the file I get the following message when I try to load the Skin in Virtual Vinyl: Invalid skin file (error line 37 in the xml)
1: Is it possible to use skins with Virtual Vinyl? (I'm assuming it is)
2: Am I doing something wrong? and What should I do?
I'm trying to get the V-Mix 5.2. I'm demoing the product all next week and hopefully I can get this skin to work as I want the best one for video.
Thanks in advance,
Charlie Five :: Visualize Chicago
www.visualizechicago.com
www.myspace.com/djcharliefive
geposted Thu 07 Jun 07 @ 2:10 am
sbangsPRO InfinityMember since 2004
yes it works in vv as its the same program
what is the screen resolution set at in windows?
do other skins work?
geposted Thu 07 Jun 07 @ 2:25 am
Thanks for the response. I'd really like to get this skin before sunday afternoon...I'm doing a sound/video test at a local nightclub on sun, then doing a full Demo at that spot on Tuesday. All vids!
I have tried many different things. I keep getting the same error message I mentioned above. ^
1 - I can change my screen resolution to whatever need be.
2 - No, other skins do not work.
geposted Sun 10 Jun 07 @ 2:39 am
its best to make a ticket on this one it might be bootcamp thats interfearing
i havent had much chance to try it out yet.
make ticket
geposted Sun 10 Jun 07 @ 12:19 pm
tafarieHome userMember since 2007
i really need to try
but how
geposted Tue 12 Jun 07 @ 4:00 pm
but how
sorry i dont follow ?
please explain your problem
geposted Tue 12 Jun 07 @ 6:02 pm
bogartPRO InfinityMember since 2004
CHARL1E F1VE
I had the same problem with the same skin.
I deleted it and redownloaded it. The re installed and it works now.
Not sure if this will help , but worth a try.
geposted Tue 12 Jun 07 @ 10:26 pm
^ Thanks tried it a few times actually. Didn't work.
geposted Wed 13 Jun 07 @ 10:32 am
make ticket
Thanks Sky. I guess I'll send a ticket tomorrow. Its weird that Bootcamp would be causing problems though, but ya never know.
I really want this skin. Anyone else? Any other ideas? Skin peeps?
geposted Wed 13 Jun 07 @ 10:41 am
JeremKPRO InfinityModeratorMember since 2004
I might have the solution.
could you send me a PM with your email address, it would be easier to find the solution i am thinking of.
Or even if you have msn messenger, that would be the best.
my msn messenger address is in my blog: http://www.virtualdj.com/blog/JeremK/blog2441.html
(it is also my email).
geposted Wed 13 Jun 07 @ 10:05 pm
