How do I put the main mix through the speakers and listen separately through the headphones. It seems like a lot of people have this question too. The process to make it happen is very confusing.
geposted Fri 15 Jun 07 @ 9:42 pm
Are you using the trial or a craked V4 as this won't work with the headphones.
If you have MK (which it says on profile) then just plug headphones in front and away you go.
geposted Fri 15 Jun 07 @ 11:53 pm
Im using Virtual DJ Version 3.4.1. My console doesnt have a headphone input. Cant I just use it through the soundcard?
geposted Sat 16 Jun 07 @ 3:47 am
ok i take it you own the mp3 control you need a 5.1 soundcard to prelisten a usb one they can be purchased quite cheaply
geposted Sat 16 Jun 07 @ 4:28 pm
Creative have a good and cheap 5.1 external sound card, from between £20-£25 I think, here in the UK.
Jimmy b
Jimmy b
geposted Sun 17 Jun 07 @ 3:29 pm
I'm using a laptop and just recently bought a usb 5.1 external sound card to enable me to listen to the next track on my headphones and play the sound on my speakers. What to do I need to do to enable this. I have the DJ Control MP3 with VDJ Home edition. I tried modifying the vdj software to enable this feature but it says I have to have the Pro version. Is this correct?
I'm using a Trsut 5.1 usb sound card.
Can anyone help me on setting this up.
Thanx in advance
Thanx in advance
geposted Tue 19 Jun 07 @ 1:33 pm
If you select the computer's own soundcard (Realtek somethingorother) as a second card, you can prefade through the computer's own headphone socket, usually on one side or somethines the front, depending on the adapter - use the USB as the main one and the computer as the 2nd one.
geposted Tue 19 Jun 07 @ 4:07 pm
