Im having problems with these two, it seems that evrytime i run msn i cannot go online with anyother program, IE, Shoutcast DNAS, etc. MSN must be the only program online otherwise it disables my conection and i have to restart my laptop.
This started just recenly, i bought a new laptop with vista, yet i seem to have the same problem with my old xp laptop, my gf has the same problem with her xp.
Anyone have any idea? Somebody out there have the same problem?
geposted Sun 17 Jun 07 @ 6:30 pm
owch sounds nasty have you tried upgrading the the latest msn and internet exploer or a reinstall?
geposted Sun 17 Jun 07 @ 8:25 pm
tried both, my isp says everything is ok at their end.
im wondering if it could be a router issue, both myself and my gf have the same router brand, TrendNet, but we live in different parts of town, do these programs use a specific port?
geposted Sun 17 Jun 07 @ 8:41 pm
it uses many ports and will bind to the nearest free one and uses the base of port 80 which is the same for internet
geposted Sun 17 Jun 07 @ 9:31 pm
ok so im guessing the ports are ok since i can conect to the internet for hours with no problems, then why would there be a conflict with msn? any ideas? I already checked for firmware updates for my router and modem and i have the latest, windows, IE & msn i have intalled latest updates.
geposted Mon 18 Jun 07 @ 5:01 am
Have you tried firefox? Sneaky thing even gets around the proxys at work.
geposted Mon 18 Jun 07 @ 5:31 am
Have a go with Alias.
It gets round almost anything. I work in Saudi Arabia and havent found anything (yet) that will stop it. You can launch IE while using any other program.
Good Luck
DAZ
Good Luck
DAZ
geposted Mon 18 Jun 07 @ 7:43 am
Well you can try Yahoo and just add all your MSN contacts since with you can talk to both on that.
geposted Mon 18 Jun 07 @ 2:16 pm
