OK I really don't ask ? on the board but I can't find this issue and I also can not fix it. I am a DJ/Computer tech and just built a $2000 PC for a club. I use the Total Control from Numark and CUE Pro. I have two video cards and four screens. Two Flat and two that go out to the club system. I can get the video to play on any screen but when I put the video on one of the two screens in the club I get a white box on my second flat panel and it is always on top. The second flat panel is used for video switching and power point. When the video plays I can't access anything behind the white box.
Does anyone know what is causing this?
Thanks
John (DJ Ricco)
Thanks
John (DJ Ricco)
geposted Sun 17 Jun 07 @ 11:44 pm
Hi, so just to check, you've got a PC with two video cards, each of them has two video outputs, so you've got everything connected and four different monitors coming off the computer?
Then you've got one screen with the main virtual dj window, then a second one to play the full screen music videos on.
But then when you do that the other two screens go white and you can't get anything else show on them (like powerpoint,etc)?
geposted Mon 18 Jun 07 @ 1:30 am
Ok I have got it figured out! This is for information and for anyone else with the issue.
I am using Ultramon (which I think is the bomb for multi display). I had the two external (remote) screens enabled and ignored so the mouse would not goto the external screens. When this is enabled in ultramon it confused CUE. CUE would play the video on one of the extenal terminals but would also try to display it on the second flat panel resulting in a 800x600 white box on my 1024x768 screen. The White box was that size because that is what I have the TV outs set to on the two 256MB DDR2 Geforce 6500 PCIe Ultra2 video cards.
Also after a few video mixes I would lose all CUE video screens.
Once I set the two screens to not ignored all started to work great.
Thanks for the help!
John (DJ Ricco)
John (DJ Ricco)
geposted Mon 18 Jun 07 @ 3:22 am
Thank you for this very interesting report
geposted Tue 19 Jun 07 @ 3:28 am
