Forum: Old versions
Topic: Virtual Folder freezes/ crashes
When adding songs into a Virtual Folder, it crashes or freezes the program. Sometimes after adding a few songs, sometimes after adding a bunch - totally random. When you reboot the program, all the songs I moved into a Virtual Folder are gone.
I've had this problem with the demo and with the latest version. It's very frustrating.
I'm running an ASUS Duo Core 1.6
2 G Ram
thanks!
geposted Fri 22 Jun 07 @ 12:50 am
What I would do is make ur list then save it as a Playlist. Pretty much the same effect as the Virtual folder but without the hassle. The Virtual Folder issue is bein looked into if that helps ya out. If u need more help don't hesitate to ask as we all are a friendly bunch here and thats what I love about these forums.
making a short cut to the auto save may help also that way you save it before shutting down may help but may not test by making a second virtual folder and tossing in songs and shut down and reload vdj and see iff its still there if not do the same again and hit the auto save key that u made and see if it stays then. i had to do this for anilizing files and it helped a great deal
