Forum: Old versions
Topic: Can I alter Screen Size
When I open VDJ on my PC the skin ( Home edition ) it fills my 17 inch lcd monitor, But when I open up VDJ on my laptop it does not fill all the srceen ( 15 inch ). You can see about 2 inch of my desktop behind it.
When I try to maximase it, it fills the screen but the skin losers some of it's sharpness and doesn't look right. Is there a way I can fill my Laptop screen, without losing any quality.
geposted Fri 22 Jun 07 @ 11:09 am
Make sure the screen resolution on the laptop is set to the same size as the skin. If you are using a 1024x768 skin then the laptop should be set to the same resolution.
Cheers cstoll, Sorted now.
Or press the square - you have an underscore cgharavcter (minimize), a square (restore) and a cross (exit) - usually found in the top right-hand corner of any Windows software.
