how do i reactivate vinyl control? after 4 songs of mixing i loaded up a song on the right table and there was no control ,but the turntable on the screen is moving with my vc.
btw, this is vdj 4.3 and serato sl1 (asio driver beta 2) with Serato Time Code vinyls im using.
and sl1 asio driver and Serato TC it really works well if anyone wanted to know. sh-ts impressive, though im working on getting the actual VTC to get the better feel.
.... help ne1?
.... help ne1?
geposted Tue 26 Jun 07 @ 2:13 pm
4 songs with instrumentals i might add. its actually 8 songs then the vinyl control stops......
help....
help....
geposted Tue 26 Jun 07 @ 2:51 pm
im glad you are trying out the program
i would strongly recommend , that you uninstall 4.3 ,
fully and totaly, then install the latest offical demo ,
set it to peformance , to fastest
latency to auto , and it should work much better :)
hope to see you with us soon as a pro user
geposted Tue 26 Jun 07 @ 2:58 pm
ahhh, is it a software protection glitch?
neway if everything goes well, im going for pro.
geposted Tue 26 Jun 07 @ 3:13 pm
cracks or mods can seriously screw the software yes
do a full uninstall , then install the latest demo
geposted Tue 26 Jun 07 @ 3:34 pm
You loose vinyl control simply because VirtualDJ is not compatible with the serato vinyls
geposted Wed 27 Jun 07 @ 12:05 am
actually i didnt loose vinyl control with the demo simply using ssl records. works like a pro. i do need vdj records for the needle drop feel tho.
geposted Wed 27 Jun 07 @ 4:33 pm
