Hi every time i load my VDJ up and go live broadcastin it goes realy slow. i looked at my perfomance and its using all of my cpu usage. And the song skips and jumps and when i crossfade and do all the beats and stuff its skipping. And it sounds realy bad =( .... Please someone help me thanks .....
geposted Thu 28 Jun 07 @ 12:38 am
what is your system spec?
what version do you use?
geposted Thu 28 Jun 07 @ 12:43 am
hi what is sytem spec ? =P
and it is VDJ v4.2
and it is VDJ v4.2
geposted Thu 28 Jun 07 @ 2:39 am
sys specs is..
type of CPU
size of Hard Drive
Operating System
amount of memory
version of VDJ using
type of sound card
type of video card
I hope this helps...
type of CPU
size of Hard Drive
Operating System
amount of memory
type of sound card
type of video card
geposted Thu 28 Jun 07 @ 2:43 am
oh ok thanks erm ..
harddrive size:37.2GB crap
computer:intel(R)
pentium(R)4
CPU 2.80GHz 2.79GHz
376MB of RAM
is that what you wanted to know ?
computer:intel(R)
pentium(R)4
CPU 2.80GHz 2.79GHz
376MB of RAM
geposted Thu 28 Jun 07 @ 2:54 am
Still missing some info.
Sound Card
Video Card
Version of VDJ
My recommendations:
Get more RAM, and a bigger hard drive. I'm guessing your video card is onboard the motherboard which won't cut it.
Sound Card
Video Card
Version of VDJ
My recommendations:
geposted Thu 28 Jun 07 @ 3:10 am
ok i don't reali know which one it is so i will put evrifin thats there =P..
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
SoundMAX Intergrated Digital Audio
Unimodem Half-Duplex Audio Device
Video Codecs
Thats all the things i found and my version on VDJ is 4.2
i hope im right =P
Audio Codecs
Video Codecs
i hope im right =P
geposted Thu 28 Jun 07 @ 3:38 am
I would upgrade to at least 1Gb ram and maybe get a bigger hard drive. Have you optomized your system for VDJ?? Get rid of unecessary processes that are runnin while usin VDJ.
geposted Thu 28 Jun 07 @ 4:02 am
oh ill have tu save up a bit of money =P
and yes ive closed all programmes down and done VDJ by its self and it still goes slow
it must be my pc thanks for your help =D
geposted Thu 28 Jun 07 @ 4:20 am
Oops Derrick I didnt see that you posted the same thing as I just posted :)
geposted Thu 28 Jun 07 @ 4:33 am
Thats okay, the more help, the merrier! DJ Frankie, looks like you may have an onboard video card that doesn't do hardware acceleration. In layman's terms, the computer is doing all the work of moving the pixels around on the screen. When dealing with videos, that is a lot for the CPU to handle. When you use a graphics card with Hardware Acceleration, the graphic card does all the hard work, freeing up the CPU to do other less taxing things. Without really knowing what type of machine you are running, it is hard to recommend the proper hardware for you. If you machine a store bought machine, or something someone put together for you? If it is a store bought what is the brand and model number?
geposted Thu 28 Jun 07 @ 4:57 am
aslo
go to options > performances
set it to fastest , set Latency to auto
untick safe mode , and overclock
that should free up alot of CPU
geposted Thu 28 Jun 07 @ 10:50 am
Thank you all so much for your help
And its runnin very smooth now i can start broadcasting =D
Thanks
Thanks
geposted Thu 28 Jun 07 @ 2:09 pm
