Does someone have this type of fader? When deck A is playing... I want to slowly fade out the music by moving the fader to the right. But I don't want deck B to start until the music on deck A is 50% faded out. And when deck B starts... I want it to start at full volume (not faded in). I mainly want to use this for automix.
Is this possible? I already downloaded the crossfader curves but I am not sure how to work with them. Thanks in advance.
geposted Fri 06 Jul 07 @ 3:15 am
With the plugin crossfader curves by djcel: http://www.virtualdj.com/addons/download.html?addon_id=2775
activate the plugin in VDJ, and then you can drag the red and yellow curves to get the crossfader you want.
It is very easy to use.
geposted Fri 06 Jul 07 @ 12:16 pm
If you set it up that way from A to B then won't it do it backwards when you go from B to A. Deck B will cut out abruptly and A will slowly fade in? Just a thought, doesn't sound like a symmetrical curve.
geposted Fri 06 Jul 07 @ 3:28 pm
