at one of my gig at a club on saturday i starting playing at about 10:30. everythink was going smooth for about 2 hrs and 30 mins. i notice when i loaded my mp3 file sometime i have a delay in the software. it will freeze for about 10 seconds. then it will resume to normal. also once in a while i got a white transparency screen. i can still see the program in the background. lucky me i had a 45 minute break so i restarted my laptop. i was only mixing mp3's. I always check in my task manager to make sure nothing else is runing in the background. do you think i need more ram.
thank you.
Laptop specs
2 duo
160 gig
1 gig of ram
6150 gforce video card
thank you.
Laptop specs
2 duo
160 gig
1 gig of ram
geposted Mon 09 Jul 07 @ 10:05 pm
1gig of ram is sufficient if u only use audio tho but have u tried uninstalled n reinstalled and clean up ur OS? N also sometime a bad corrupted mp3 could play a part in this mess too:)
geposted Mon 09 Jul 07 @ 10:17 pm
no i haven't uninstalled it and reinstalled it.. it sounds crazy but what is my os mean?
geposted Mon 09 Jul 07 @ 10:46 pm
Operating system.. XP or Vista? Reinstall or reformat it (but this is betta the last option u do) N save ur VDJ database to a external media such as cd or storage card b4 u do this. But first just try to reinstalled the program n these too pls save the database b4 u uninstalled the program:)
geposted Mon 09 Jul 07 @ 10:50 pm
well the laptop is about 2 month old. im runing vista on it. this is a very clean laptop i only us it for vdj. so maybe it was a mp3 file. is there any way i can scan all my mp3s for problems?
geposted Mon 09 Jul 07 @ 10:58 pm
By scanning i not sure, but the other way is to play it n see which file is damaged by doing it one by one(koe this is tedious but it worth a shot):)) n good luck
geposted Mon 09 Jul 07 @ 11:03 pm
just before you wipe your whole pc
try the following on options --> performances
set latency to auto , untick safe and overclock , set the slider to fastest
run a system defrag and a disk check , by going to my computer and rightclicking your harddrive or drives and pressing properties , and then on the tool menu run all the tools
these will speed up peformance and repair any bad files
if this doesnt help dont worry i have a few more tweaks aslo :)
hope that helps
hope that helps
geposted Tue 10 Jul 07 @ 3:42 am
thank you, i will do so.
geposted Tue 10 Jul 07 @ 5:08 am
The white transparency screen is caused by vista when a program doesn't respond anymore.
geposted Wed 11 Jul 07 @ 10:53 am
