Forum: Old versions
Topic: Vdj stops & speeds up
What am I doing wrong? When a song is playing and I type in a song for the second deck, some times the program will stop or sync will light and it will speed up. I have to close the program and reopen it to correct this. This is not cool when performing. I think I want to go back to 3.4
geposted Tue 10 Jul 07 @ 10:42 pm
(sync will light and it will speed up.....)
Try disable the auto pitch match in config. C if these helps:)
Thanks, I tried that but it still happens,but only occasionally. Now when I load the second deck the volume on deck one cuts in half. Everything was working great until I upgraded to the current version.
Hi , at config go to options n at disengage beatlock choose manual... and auto pitch match disabled:))Hope that helps
Man -I had the same think happen last week.....Same scenario; typing on the keyboard...Deck two speed up; the sync button is locked and illuminated....very frustrating. i had to close the program to rectify it.....
I'll try thge above solution...Hopefully that will resolve it....
delere the "B" keyboard shortcut; this is beatlock, or change it to a 2 or 3 key short cut.....
exact same issue I have sometimes..
Go to the "Keyboard Shortcuts" pannel in the VDJ config and activate the option "Disable shortcuts and use keyboard for search only"
