What am I doing wrong? When a song is playing and I type in a song for the second deck, some times the program will stop or sync will light and it will speed up. I have to close the program and reopen it to correct this. This is not cool when performing. I think I want to go back to 3.4
geposted Tue 10 Jul 07 @ 10:42 pm
(sync will light and it will speed up.....)
Try disable the auto pitch match in config. C if these helps:)
geposted Tue 10 Jul 07 @ 11:00 pm
Thanks, I tried that but it still happens,but only occasionally. Now when I load the second deck the volume on deck one cuts in half. Everything was working great until I upgraded to the current version.
geposted Thu 19 Jul 07 @ 4:43 am
Hi , at config go to options n at disengage beatlock choose manual... and auto pitch match disabled:))Hope that helps
geposted Thu 19 Jul 07 @ 12:19 pm
Man -I had the same think happen last week.....Same scenario; typing on the keyboard...Deck two speed up; the sync button is locked and illuminated....very frustrating. i had to close the program to rectify it.....
I'll try thge above solution...Hopefully that will resolve it....
geposted Sat 28 Jul 07 @ 4:01 am
delere the "B" keyboard shortcut; this is beatlock, or change it to a 2 or 3 key short cut.....
geposted Sat 28 Jul 07 @ 4:13 am
exact same issue I have sometimes..
geposted Thu 02 Aug 07 @ 1:30 am
Go to the "Keyboard Shortcuts" pannel in the VDJ config and activate the option "Disable shortcuts and use keyboard for search only"
geposted Mon 06 Aug 07 @ 1:12 am
