Forum: Old versions
Topic: cue/mix volume control
Hi all,
The manual shows a headphone and a cue/mix volume slider on top of the skin but none exists on the default video skin that comes with 4.3, how do i adjust the cue/headphone volume within VDJ? Does the DAC-3 custom mapper have a way of controlling it?
Thanks in Advance!
geposted Thu 12 Jul 07 @ 1:53 am
Why don't you edit the skin using parts of the internal mixer interface and put them in the fullvideo skin?
You're better off using an external mixer - The DAC-3 and the mapper is designed with this in mind. You can't control these with the DAC-3 mapper.
My DMC-2 mapper (For the Numark DMC-2) does allow this though in Mixer Mode, but again, it's better off used with a proper external hardware DJ mixer.
If you want to use the software mixer in VDJ with a hardware interface, the Hercules DJ Console or Numark Total Control is better suited to this.
