hey i just downloaded the virtual dj to my program it states that i have the internal data base corrupted and it will not allow me to download new skins to my pc, everythign works but i want a new skin i have the MK2. can anyone help me please
geposted Thu 12 Jul 07 @ 3:02 am
Which version of Virtual DJ are you using?
geposted Thu 12 Jul 07 @ 3:04 am
He is using Home version that came with MK2 I presume.
For downloading some of the skins you need a Pro license. You have some skins available to you.
You can upgrade to Pro license as you have Home version here:
http://www.virtualdj.com/purchase/discount.html
geposted Thu 12 Jul 07 @ 1:06 pm
And you may want to fix you corrupted database before you find that you did all this work with no results.
When did you get VDJ. If you just downloaded it. You may want to do a fresh install to get rid of the corruption.
When you turn off the program, let it sit for a while.
geposted Thu 12 Jul 07 @ 6:22 pm
basicaly go to C:/programfiles/virtualdj
and open up the file virtualdjdatabase(yourname).XML
in text edit.
and look near the end
ensure all the song tags are closed
they should look like this
<Song FileName="10 The Ultimate [Original Version].mp3" File Size="11993410" Tag Date="701160438">
<Display Author="KrisSy; Trixta" Title="The Ultimate [Original Version]" Tag Read="1" />
<Infos SongLength="16540416" />
<BPM Bpm="17640" Phase="2352" />
<FAME Is Scanned="1" Volume="8324" />
<Atomix Mix Type="3" Tempostat="1131312" Tempo End="15807792" Cut Start="1131616" CutEnd="16336704" Fade Start="1004544" FadeEnd="16356864" />
</Song>
Notice </song> at the end it is like that some songs near the end dont have this and have corrupted the sheet below them add this tag if it is missing , and this should remedy problems
in text edit.
</Song>
geposted Thu 12 Jul 07 @ 7:57 pm
hello everyone i'm new 2 VDJ could anyone help me 2 get started because i can't get any sound from my speakers i connect like in the book but can't get any sound please i need help thank's in advance.
geposted Fri 13 Jul 07 @ 12:13 am
WELL I GOT THE CORRUPT NOTICE GONE BUT I AM STILL HAVING PROBLEMS ADING NEW SKINS TO THE VDJ
geposted Fri 13 Jul 07 @ 1:29 am
Ok Studda what happens?
please ensure you place them if in zip format
in C:/programfiles/virtualdj
if its an .exe run it and it will auto install
geposted Fri 13 Jul 07 @ 1:43 am
ok look at the quickstart manual here
at pages 6 and 7
if your still having issues let me know :)
geposted Fri 13 Jul 07 @ 1:49 am
