I have a laptop
currently I possess a card creative USB and I am thinking about passing to a card creative PCMCIA.
You recommend me to change card or it doesn't serve for the use of VDJ
geposted Thu 12 Jul 07 @ 8:21 pm
You can use both standards, it is practically the same.
geposted Thu 12 Jul 07 @ 9:07 pm
then do you recommend me not to change it or not???
geposted Fri 13 Jul 07 @ 1:39 am
to quote my favourite fraze of today "if it aint broke - dont fix it "
if u got somthing thats working stay with it :)
geposted Fri 13 Jul 07 @ 1:53 am
But look at it this way if u use the PCMIA card you open up a USB slot for somethin else.
geposted Fri 13 Jul 07 @ 2:24 am
I couldn't say it better :)
Stay with USB if it works for you, and if you need extra USB ports there is PCMCIA to USB expansion card ;)
geposted Fri 13 Jul 07 @ 11:10 am
Ok.
thanks for yours advices
geposted Fri 13 Jul 07 @ 12:05 pm
No problem, anytime ;)
geposted Fri 13 Jul 07 @ 6:38 pm
