i have a hercules mk2/virtual dj, but i cant seem to get any sound with it from my pc speakers, only external speakers or thru the headphones. any help appreciated, thanx
geposted Thu 12 Jul 07 @ 11:26 pm
Desktop or a laptop?? If it is a desktop plug your speakers into the MK2. If it is a laptop, i dunno as I never used the home version.
geposted Thu 12 Jul 07 @ 11:31 pm
If you want sound to come out of your laptop rather than your external speakers (you can only have one with Home Edition, unless you buy Y-Splitters) do the following:
Connect the cable which came with the Mk2 (it has red and white RCA connectors and a 3.5mm black one). The red and white RCA connections go into Output 1/2 of the Mk2. The 3.5mm jack plugs into the line-in of your laptop. Then open windows sound panel (double click on the speaker next to the clock) and untick line-in.
geposted Thu 12 Jul 07 @ 11:34 pm
its a desktop, thanx for your help lads
geposted Thu 12 Jul 07 @ 11:47 pm
this feature is included in virtual dj pro aslo
it unlocks the two soundcard mode
if you dont wana cable :)
geposted Fri 13 Jul 07 @ 3:26 am
