how can i make longer loops that just four beats per loop?
geposted Fri 20 Jul 07 @ 10:13 pm
Loop in at your start point, and loop out at what ever point you want. Or the default skin has auto loop points from 1/4 to 16, and if you click on the arrows beside them you can double them.
geposted Fri 20 Jul 07 @ 10:24 pm
what i meant was the i want to make sample loops that are longer than four beats per loop.
geposted Fri 20 Jul 07 @ 10:31 pm
What do you mean?
geposted Fri 20 Jul 07 @ 11:15 pm
When I try to create samples longer that four beats, it creates them as "jingle" samples. How can I create them in "loop" mode that are longer that four beats?
geposted Fri 20 Jul 07 @ 11:24 pm
Open the sample module, play your loop, record it by pressing the loop or jingle tab in one of the banks. I think you stop the recording by pressing the tab again, but I forgot.
geposted Fri 20 Jul 07 @ 11:51 pm
it's my experience that the only difference in jingle recording and loop is jingle plays once around and loop of course play until you tell it to stop. They both have the same amount of recording time.
I tried to make the loops longer with no success
geposted Sat 21 Jul 07 @ 12:50 am
what i would do is record it at the other software as soundforge etc then make it as a sample n open in vdj n set the loop n sync beat:))..sometime its help provided u record it properly n use the metronome if u plan to do ur own sample.
geposted Sat 21 Jul 07 @ 8:31 am
