Forum: Wishes and new features
Topic: a show location point [DONE]
i wish, i wish up on a star;...... there was a point where when you right clicked on a track in the track area it had show location on computer that way it would make it alot easier to modify track names commentsor whateverelse is out there and it would be perminet, wouldnt have to worry about the database so much.. like musicmatch jukebox has but there going away now and yahoo music juke box is takeing over but this could be just a dumb idea but i have use the crap out of it in musicmatch
geposted Sat 21 Jul 07 @ 6:13 pm
cstollPRO InfinityMember since 2004
There use to be a Go to Folder option in prior versions but it was buggy.
The is the File Info which gives you the path location.
You can change the Name by right clicking and choosing ReName
You can add comments by right click and Edit comment.
But I agree this should be all in one spot.
geposted Sat 21 Jul 07 @ 6:41 pm
JeremKPRO InfinityModeratorMember since 2004
Done in VirtualDJ v5.0
geposted Mon 20 Aug 07 @ 12:33 am
