Forum: Old versions
Topic: Crash on startup
I downloaded the trail version and the minute I load VirtualDJ, I get a message saying
virtauldj_trail.exe has encountered a problem and needs to close.
The error report gives me this information
AppName: virtualdj_trail.exe AppVer: 4.2.0.0 ModName: virtualdj_trail.exe
ModVer: 4.2.0.0 Offset: 0005fc73
What is going on?
geposted Sun 22 Jul 07 @ 1:58 am
try a reinstall
Plus "IF" u have used crack version b4 on the pc, do remove it completely as it would mess up the trial VDJ:))
And download trial again, it may be corrupted.
I've done all that and I am still getting that same message. Once I load up VDJ, I get to choose the interface and after the splash screen pops up, I get the crash message.
Have not been using a crack. I am just downloading the trial installer.
the Trial program works on my other computer.
Am I a first case for having an issue such as this? I can't seem to find anyone else with similar problems on the forums.
what windows do you use ?
whats your machine specification?
Hm, sound like a buggy Windows to me, you should reinstall it. I know it is a pain in the grass :) , but it will make you start somewhere.
Let us know what you did for future reference ;)
Also check to see how many background processes you have runnin, Mine runs at about 22 while I am djin. Now Vista I have no idea what I can get rid of.
