Forum: Old versions
Topic: Problems Cueing up!
Hey All!
Heres my situation. Im using a macbook, a behringer usb audio interface & Virtual DJ. I can connect everything fine and I can hear the output , but for some reason I can't cue up a song while one is playing.
Is there something I need to do with the settings? Is the behringer usb audio interface a bad idea?? Should I go with an iMIC???
Help!!!
geposted Sun 29 Jul 07 @ 9:03 am
Are you using the mac version, or windows version with Bootcamp?
If you bought the software, don't forget to put your serial number in your profile: http://www.virtualdj.com/fusers/modifuser.html
so you will be seen as a registrated user.
I am using the mac version.
Thanks
Well it seems the version you are using is illegal.
Because there is no trial version of VDJ for mac out yet, and you didn't buy the software.
No help is given to users who are using illegal versions.
If you get legal, you will be provided all the help you need.
