Forum: Old versions
Topic: video fx plugin to add fx on ether deck
hi did any one come out with a plugin so where i can add the video fx on any of the decks instead of the main video.like for example .lets say i play video on on the left deck normal.ok
know i whant to be able to fade the other video in with the fx i added to the other video .so the video on second deck will have the fx instead of the main video that the peaple see
geposted Tue 31 Jul 07 @ 7:28 am
It needs to be directly implemented in VirtualDJ
ok has any body directly implemented it.
Hi, I think the short answer is no.
Not sure what the plans are for the next versions of VDJ, but i guess it must have at least been considered at some point. Like DJ CEL said, the development team would have to add this to the program.
Also, if you like using video effects, have you found that you can use "freeframe" video effects in virtual dj.
yes thank you .
i do know i have every fx vjd came with plus the one's from pete plug ins and more.
i just think it would be more fun and badass if we can just use the effects on what ever deck we whant same way we can do with the sound fx.
definately would be gud!
Hopefully some time in the future...
