A suggestion to create an optional line (by default use the
name of xml) or parameter of "Skin" in the header of XML,
where a user can specify the location of .bmp image to be
used. For example:
This way a skin creator could build one image, and then
include several different .xml files with different resolutions
or modes, without the need to duplicate the .bmp to match
the name of .xml, thus reducing .zip file size.
used. For example:
<Skin name="SkinName 1024×768" File name="SkinName.bmp" version="4" width="1024" height="768" >
geposted Wed 01 Aug 07 @ 7:47 am
Yes this is a good idea.
geposted Wed 01 Aug 07 @ 12:49 pm
