Hello,
I've got a laptop with a 1440 x 900 screen.
When I try to resize a skin, the outputfile of the bmp is 1440 x 4180.5
When I resize the xml file it can be resized to 1440 x 900.
Why doesn't that work with the bmp file?
Now I can't use a 1440 x 900 skin
geposted Wed 01 Aug 07 @ 9:32 am
Ask in skin forum...
The resizer is made by a user, and its better chance for him to see your thread there :)
If the XML file is right, do this :
- Open the BMP in a photo editor from inside the ZIP file. Resize the WIDTH to 1440 pixels, and KEEP aspect ratio.
Save, and put together with your new XML file (from skin resizer), and pack as a zipfile.
geposted Wed 01 Aug 07 @ 9:36 am
djanthony wrote :
Hello,
The file might actually be CORRECT
The skin BPM have lots more info that what you see in VDJ when running the program.
All "mouse over graphics", button hovers etc are BELOW what you see when running VDJ, so the BPM height SHOULD be a lot more than 900 px
geposted Wed 01 Aug 07 @ 9:38 am
Thanks dj-norway for your help and quick answer !!!
geposted Wed 01 Aug 07 @ 9:52 am
Only problem is :
Take a skin, resize xml to 1440 x 900 and bmp to 1440 x 4180.5
Software is doing his job and says that everything was succesfully resized.
When I go to the config from virtualdj and choose the new skin, it looks scrambled.
geposted Wed 01 Aug 07 @ 9:56 am
Sorry. I've never tried the resizer tool, and not sure how well made it is.
I think it works pretty good for the XML (coordinates changed by simple math).
But not so well for BMPs.
So try change the BMP in a photo editor (set width, keep aspect ratio)
Or ask in skin forum, there are lots of great skin makers there ;)
geposted Wed 01 Aug 07 @ 5:11 pm
thanks for your help.
Where can I find the skin forum ?
geposted Wed 01 Aug 07 @ 5:16 pm
geposted Wed 01 Aug 07 @ 5:19 pm
Thanks mate !!!
You are fast
You are fast
geposted Wed 01 Aug 07 @ 5:23 pm
