Hi guys, HERE is the temporary solution to make the jog wheel works on bcd with vdj 4.x just follow the instructions on my blog and have fun...
Enjoy it....! ;)
Dj Quintana
Enjoy it....! ;)
Dj Quintana
geposted Tue 07 Aug 07 @ 5:00 am
Good work man ;)
geposted Wed 08 Aug 07 @ 1:31 pm
do you have something like this for mac?
I don't think my laptop supports dlls.
geposted Wed 08 Aug 07 @ 6:42 pm
A little bit heavy your blog Julio but I could finally open it hehe :)
geposted Wed 08 Aug 07 @ 6:52 pm
Wonderfull! Thank you for your work.
Is it possible to send back midi-signals to let glow the led's?
Now i will try some solutions, like change Pitch Bend/Scratch Mode, etc.
If the team is not able to give a solution, we have to do it ;-)
With regards and have a nice day
Mitch
Mitch
geposted Thu 09 Aug 07 @ 2:58 pm
yes is possible, but don't know if with Texzk's mapper .
geposted Fri 10 Aug 07 @ 6:10 pm
I made a new configuration with texzk's mapper , everything is working fine but the leds and a little bug with loop out that probably will be solved soon; bcd3000 users can visit my blog and follow the instructions :)
geposted Tue 14 Aug 07 @ 2:42 am
How about higher level for your blog?
geposted Tue 14 Aug 07 @ 5:26 pm
manquin dj, is there any way you can map the bcd3000 so that you can use the effects and beatlock.
geposted Sat 18 Aug 07 @ 3:45 am
Okay, this gave me encouragement to install the demo on my home computer. I really do like it, but is there a tutorial somewhere about how to edit the configuration? I would prefer to separate the crossfader from the audio in video mode. I'd like to just use the regular slide faders to control the mix, and the crossfade to transition the video. I configured it that way when I was trying it on my laptop, mapping it through midi myself. I don't know much about how the workarounds posted here really work, but it seems that since they're still midi controls that they should be able to map similiarly.
Great work! It gives me hope that the next version of Virtual DJ will make me a customer!
geposted Sat 18 Aug 07 @ 7:03 am
In the demo go to Gonfig/Video and uncheck the Link Crossfader box and that seperates the crossfaders.
geposted Sat 18 Aug 07 @ 10:37 am
Sometimes it doesn't work, I prefer to do it in config. go to options "crossfader" deactivate.
geposted Sat 18 Aug 07 @ 8:03 pm
@urban001
yes is possible to map the effects and beatlock using Texzk's mapper, is very similar to midi mapper,regards.
geposted Sat 18 Aug 07 @ 8:05 pm
BCD3000 is supported from VDJ 5.0?
geposted Sun 19 Aug 07 @ 10:59 pm
it is possible to use it consult http://www.virtualdj.com/blog/juliocqb/
for more info
for more info
geposted Mon 20 Aug 07 @ 12:02 am
BCD3000 Jogs can be mappable with VDJ 5 and standard MIDI, native support maybe in VDJ 5.1
geposted Mon 20 Aug 07 @ 12:24 am
yes, i made a midi maper i will update my blog soon there will be some explanations to explain how midi maper works..
regards
Dj Quintana
regards
Dj Quintana
geposted Mon 20 Aug 07 @ 5:56 am
and finally here is the midi mapper for VDJ 5.0 just click on my BLOG and you'll be ready to go....:)
Dj Quintana
Dj Quintana
geposted Mon 20 Aug 07 @ 6:15 am
thanks, we want to review BCD3000 with VDJ 5.0!
geposted Mon 20 Aug 07 @ 10:59 am
