Forum: Old versions
Topic: MK2 Problem on VDJ
ok so i just bought a MK2 hercules and it works like a charm...
i'm currently running a 2.4GHz HT, Intel Based board (dont remember model), 2gig 2700 ram, X1650 512mb VC, On board 7.1 SC, SB Audigy 2 ZS...
i tried using the combo 2 SC for the main speaker outputs and headphones PFL... (obviously the SB Audigy was the main soundcard for the main speakers)
now when i plug in the MK2 Controller and plug in a set of headphones i bought for the contorller on the console... no sound comes out when i use PFL... but when i revert it back to the computer sound cards it works. Is there something wrong with my controller or am i not setting up something right?
please help ^_^
geposted Tue 14 Aug 07 @ 6:53 am
just a question...why are you using 2SC? MK2 does it for you. It works perfecly without a second SC...
What version u running? As far as i koe djc edition did not have other options rather than using the mk2 soundcard and as the controller..R u using the trial??
Yes i am using the 4.2r trial version.. ive been playing around with VDJ prior to purchasing the MK2 controller... and before i had purchased it i had 2 SC regardless... but what should i do? do i revert back to the 3.4? i was thinking of also purchasing the 4.3....
i just need something that will give me a solution to the MK2 controller working seamlessly
Ok try this..
Input: none
Output: headphones
Card: mk2
Output channel: master channel 1/2 /headphones 3/4
Above is the basic if u gonna use timecodes it a bit different..
cheers,,
N u wont regret if u purchase 4.3 as it a FULL package..n u could have the discount:) n upgrade coming soon n of course its free too..
Hope to see u as pro soon:)
well i have my computer sound system connected to the SB Audigy Card... so when i work with the set up u gave me spinna no sound comes out...
with the MK2 that means in order to use the headphone plugs on the contorller i HAVE to use ONLY the MK2 and no sound cards from the PC?
The output of the mk2 go straight to the speaker or amp or external sound mixer which then back to ur 2nd card for example. Or if u wish to use 2 card there an option too...with external mixer mode. Just do a trial n error method..:)
Not really... if ur com soundcard is 4.1 or greater u still could use it to prelisten..
I use mk2 (but i only use this one often as the sc) n sb audigy zs pro platinum n it werk perfect.. i also use some usb audio interface from behringer as back up..:)
Let me know if that werk n if u need more help.. :)
Btw r u using audigy 2 zs or audigy 2 zs pro platinum (came with the i/o hub)
just 2ZS no i/o hub but i will try to get it to work. trial and error i suppose... thanks for everything
Good luck. n let us koe if u still can't get it right, we always be here:)
U could also checkout Skyfxl blog.. there a lotsa interesting thingy there:)
http://www.virtualdj.com/blog/skyfxl/
Thks to simon:)
review mk2 drivers.
when you plug mk2 sc works separately. this means that you should hear audio reproduced from vdj through mk2 audio output (out 2) and other windows programs audoi will be reproduced trhough your system card...
Also update mk2 firmware...
hope this can help
where can i obtain the new firmware/drivers for the mk2?
links?
update!!!
ok so i tried it on a laptop of mine that only has the SC built in and used the MK2 in a way that the sound comes out thru the output1/2 of the console... now the headphone jack in the front of the console only works on Mix and Split... but not Deck 1 or 2... are those reserved for the RCA inputs in the back? or is something wrong with my console?
i cant mix without listening to the decks individually! help
something shoud be wrong.. headphone is independent so this channels are not reserved for RCA. you should be able to listen also deck a & B separately...in fact MK2 acts as 2 SC
Have you updated VDJ to 4.2r1 version? this one is specially fitted for MK2 use
ALRIGHT! I GOT IT TO WORK!
Setup
Input: none
Output: Headphones
SC: MK2
The ONLY difference is that the speakers i use to listen to the songs HAVE to be plugged in from the MK2 and not my computer SC... now everything works perfectly!
^_^ im so happy
at 5:44 in the effing morning i am a happy man!
thanks to everyone that tried to help me like spinna n djkike! <3
Nice:D
That what i been trying to explain to u..:)
Enjoy mates..
Glad to help you..
ENJOY!
Been there too dont feel bad, glad you got it sorted:)
yeah, teamer always there, i can certify after more than 4 years around here...
