Forum: Old versions
Topic: Studdering and crashing???? HELP!!!
I have been using virtual DJ here and there. I have version 4.3 I think. It will play for about 4 or 5 hours, and then it just starts to studder or will lock up on me. I have a dell laptop with 1.8ghz processor and 2gig of ram. I also have problems sometime with the playlist. It will drop songs when it is auto mix mode, and when I do a local search alot of times it wont load from the results found, I have to go to the actual folder. What is wrong!!!!!! I have no stability with this program, but I love it. Time for Serato I guess...........
geposted Thu 16 Aug 07 @ 11:48 pm
No, its not time for Serato..its time to purchase Virtual..there is a code that when cracked will cause the kinds of problems you are having. Hope to see you with Virtual soon as a registered user.
it is a registered version.
Uninstall the version you have now including all the registry keys and install the current demo and let us know.
Then you might want to talk with the registered person and have them get you the latest updates.....?
Enter your Serial # here - http://www.virtualdj.com/fusers/modifuser.html
So you have it registered with the forum and get that NO License User off your name at the left.
If it is a serial # crack then sorry.
Crack kills
>:P
