Forum: Old versions
Topic: Question about deleting a sound effect- thank you.
Hi,
There are some pre-loaded sound effects that come with VDJ...
Backspin, Beatgrid, Brake, Flanger,
Flippindouble, etc.
Is there a way to delete 1 or more of these that I know I will not use so that they do not appear on the pull down list in VDJ?
I also want to ensure that I don't mess anything up if I should delete these out.
thanks for the assistance.
B
geposted Fri 17 Aug 07 @ 7:01 pm
just remove those .dll
from the plugin folders its safe to do so
What you need to do is go to the directory where the effect file is located. For example, C:/Program Files/VirtualDJ/Plugins/SoundEffect (think of the slashes as backslashes, the forums do not allow the real backslash), and delete the .dll file and, if it exists, the .ini file.
For instance, if I wanted to get rid of vocals+, I would delete the file vocals+.dll from the directory. The next time you start Virtual DJ, it will not be in the effects pane.
A word of advice...Back the folder up by making a copy of it somewhere else on your hard drive or removable media before you make changes in case something goes wrong. Then you can start over by replacing it with the backup ;)
Ahhh, sky, ya beat me :)
Does this procedure work the same to get rid of video effect like camera or strobe- just delete the .dll file?
Thanks guys- I always keep backing up the VDJ folder.
Appreciate it.
Sorry- ran out of time to edit above.
Does it also work for video transition deletion too? just get rid of alpha.dll for example if I want use that transition.
tx.
B
I'm quite sure it is the same for all effects, but I haven't tested it. Let me know how it goes, k?
~Doc
same for all effects :)
Thanks Sky-
By the way...my friend looked for ya in Atlantic CIty and didn't find ya- he said " I looked for that young wiz kid who knows all about VDJ"
maybe i come next year lol , stuck in the uk at the moment:(
Works for all, I got rid of quite a few transitions that when usin the random transition effect looked like crap.
