Forum: Old versions
Topic: A few question I would like to no
1. Why is virtual dj so expensive
2. If I bought it would it automatically configure with my mk2 or would I have to set it up.
3. At the moment I am using the free version I got with my mk2 the problem is I have a folder with over 2000 songs in it and when I try and get the bpm is takes ages and does not save bmp for next time why ????. Also when scrolling through the list it some times lags a lot why ???
thanks
geposted Sun 19 Aug 07 @ 6:59 pm
1. its a professional program , its taken alot to develope considering the money you can make from it its a good investment
2. it would automaticaly work apart from the sound options for headphones
which need to be changed to
inputs : none
ouputs : headphones
card : mk2
channels 1/2 main 3/4 headphones
3. thats probably an issue with your pc , whats its spec?
ps if you buy today only , there is a 20% discount Plus you can claim a discount becuase you own the mk2
discount
I would say as a MK2 user 5.0 is great. And the price is today only. Jump On It.
