Forum: Old versions
Topic: VDJ 5 and 1 TCV problem [SOLVED]
Hi,
congrats for the new looks of VDJ. Finally you got the pitch reset problem fixed with 1 TCV. However, you did introduced a worse problem: when choosing 1 TCV you can only control the deck number 1. If you do an auto config on channel 2 its says Error in ASIO driver. I did reinstalled 4.3 to compare just in case and it is ok when you do that.
So now I have the pitch reset problem fixed in VDJ 5.0, but I cannot use it because I can only control one deck! Can you please have a look at it.
Thanks
geposted Sun 19 Aug 07 @ 7:04 pm
Please use the deck selector so the function select() to switch between the deck
It works!!!!!!!!!
Thanks you very much finally I have my VDJ working with one TCV!!! Very good job!
