Forum: Old versions
Topic: iTunes DB
Why is my iTunes DB suddenly showing in VDJ? I do not want this there, now my searches show up all sorts of crap - how do I get rid of it?
Also is mp3database.txt used anymore?
geposted Sun 19 Aug 07 @ 9:33 pm
Go to Config and Browser and uncheck I tunes playlist.
How do you not have your iTunes database imported into VirtualDJ's database? I didn't look through the registry but did check your manual and couldn't find anything relevent. In the end I just removed iTunes, I don't really use it anymore anyway.
Uncheck the iTunes in the Config -> Browser tab
I did that, VirtualDJ still automatically imported everything in my iTunes database. I tried several methods too. I deleted the VirtualDJ database, I then cleared it of all iTunes entries and saved the file. Despite this, VirtualDJ would always populate its database with my iTunes contents creating loads of entries for files which I am never going to use with VirtualDJ.
Same problem as Andrew97 still, I have unticked iTunes playlist but I still get results from the iTunes Library in my search results. How do I get rid of this please? And there is nothing about removing imported iTunes playlists in the user guide.
