Forum: Old versions
Topic: Deck Load
Only one deck loads when automix is on. How do I change it to load and mix from both decks? It's nice to see what is coming up next right on the deck. Also, after a song is played it stays in the playlist. Is this new? Also, it isn't mixing smooth. All the cue points are different for different songs. I want to be able to make a playlist and let it automix on it's own smoothly. I know the problems were supposed to be fixed in v5 so what do I do to make this work.
Thanks
John
geposted Mon 20 Aug 07 @ 3:25 am
That is the way it is designed to run. You cannot change its behavior. Read the manual:)
Found the manual last night. All is running smooth now. Do miss the auto load on the other deck though. Thanks for the reply.
John
Why? This way you have the other deck free to add something to the mix if you want ;)
