Is version 5 harder on the cpu/ram than 4 or the same or better? Before I install.
geposted Mon 20 Aug 07 @ 7:56 pm
same as 4
geposted Mon 20 Aug 07 @ 8:05 pm
Thanks, guess I have something to play with tom.
geposted Mon 20 Aug 07 @ 8:09 pm
Hey there!
Good to see a fellow "Doc" on the forums :D
I've been doing some preliminary testing, and I think it's about the same as v4, if not better. For example, just for kicks, I went ahead and set the performance slider as far to the right as it would go, and so far no problems at all. Used to have a bit of trouble with this setting in v4.
geposted Mon 20 Aug 07 @ 8:27 pm
It should be a little bit better in V5.0 because there were some improvements in the sound engine.
geposted Mon 20 Aug 07 @ 11:24 pm
In VDJ 4 I used to sometimes get a small halt in a video that was playing when I loaded another video into the other deck- it's gone now with versioin 5!
geposted Tue 21 Aug 07 @ 4:00 am
Man, ya guys are teazin me. Can't wait till tom. to play.
geposted Tue 21 Aug 07 @ 4:54 am
Hi, i need to run VDJ 5 at much higher latency then VDJ 4 i dont understand how this can not be a case of higher tax on the system... here my specs (i need to run at 23ms, instead of 5/11ms as before)
Mac Book Pro 2.4gb 2gb Ram
Motu Connectiv
Pioneer DMJ800 (midi connected)
Denon 3500's for the TCCD's (relative mode)
External FW800 Hardrive
Any suggestions on setup tweaks are welcome... i kept initially the same settings as i had before, but a lot of stuttering was happing..
Motu Connectiv
geposted Tue 21 Aug 07 @ 9:05 am
Anybody?
geposted Wed 22 Aug 07 @ 4:09 am
