40.000 music files
40 covers in 1 day
That´s 1000 days = almost 3 years.
Great, in 3 years my collection is up to date !!!
p.s.: Only if when I stop now with putting music on my laptop
40 covers in 1 day
geposted Wed 21 Nov 07 @ 9:42 am
VDJ does it's best to download the covers if exact matches are found on the net. Try the auto download option first to make sure VDJ has downloaded every cover it can find exact matches for. Unfotunatly as filenames differ, and files on the nat may be spelled incorrectly and vice versa this is the only way to do it.
Otherwise VDJ only dowloads covers for the 8 or so covers that are showing on the screen at one time, on the proviso that exact matches can be found, the shortcut to this is as I suggested before, SHIFT select a few hundred files, rightclick "Download cover" and leave pc on for a bit to download the covers it can find. Then select the next few hundred.
Then create a filter for "hascover=0" and you can then go through this list just manually adding the covers for the files you think you will play. Uninportant music can just be left coverless!
geposted Wed 21 Nov 07 @ 10:43 am
Thanks halo_djk !!!
Gonna give it a try.
geposted Wed 21 Nov 07 @ 11:02 am
Djcel,
I was out for a few weeks, now installed and tested this plugin.
It really rocks man - super.
Thanks to your efforts and plugins, VDJ remains the best in the world.
Greetings
Johans
Greetings
Johans
geposted Wed 21 Nov 07 @ 7:48 pm
V2.0 of the plugin would be great. :o)
geposted Tue 13 Oct 09 @ 3:58 pm
Hi djcel
Great Job
I got the Show Cover plugin and it Works Great,
Also I like how you can adjust and set the cover to disappear, \"Big plus\".
Would like to see the ability to move the position of the cover to the right corner of the screen so it doesn\'t interfere with the Titler Title screen on the left
Would like to see the adjust to disappear function in the Titler plugin, since it gets in the way of my Sing A Long Music Videos.
Is this posible?
Thank You
Joey....
Here\'s an example:
Great Job
Is this posible?
Thank You
Joey....
Here\'s an example:
geposted Fri 16 Oct 09 @ 9:51 am
As an extention of this I would love to see this become duel purpose. Show the cover for an amount of time set by a slider, then spin around to reveal the DJ's logo till the next next cover needs to be shown.
Not sure if you modify the Showcover logo, to include the DJ logo, or modify the Showlogo, to include the cover, but the end result is the same.
Ive been using both for years now, but always wanted a slider for the time delay on Showcover, as I feel it fades out too soon. Having both plugins combined also means one less running video plugin, meaning your video quality will also be better. (IE VDJ Video plugin issue where video "focus" gets worse with each extra video plugin you run).
geposted Sun 25 Oct 09 @ 7:49 am
Only recently found this very nice effect. Hopefully DJCEL will some day deliver a new version that reads from tags if no image found in file system but this is a nice to have. Thanks.
geposted Fri 20 Nov 09 @ 4:14 pm
