Forum: VirtualDJ Skins
Topic: Skin Request
Hi everyone,
Does anyone know of any Skin available 1024 x 768 that has the following :
1. Supports Video play(Can see the video playing on the Main skin)
2. Has an automix function( I just mean that when you press a button it will start to mix to the other deck and start it playing)
3. Has an external key changer on the main skin for Karaoke so you can change the key up or down without having to go into the effects settings.
Cheers
Billy24
geposted Wed 22 Aug 07 @ 3:10 pm
I have one that can do this, but it was never accepted into the download area.
The actual keychange has to be done through the effect, but the next version (for 1440x900) will actually have buttons to change the key independently on each deck. Unfortunately, I started that project several months ago, and didn't get real far with it yet.
Let me know (via PM) if you're interested in having a look.
-J.D.
