Another newbie question,
How do I create and save que points. I have not been able to find it in the manual. Probably simple, please advise.
Thanks,
Scott
Thanks,
Scott
geposted Fri 24 Aug 07 @ 6:37 pm
Find the spot that you would like a cue point usually start at first beat intro. Hit the number one on the Skin, next find the second cue place and hit number 2. Do the same for the third cue point if desired. If you place you mouse arrow over the cue point and right click, you can even rename the cue point.
CLUE: Don't hit the numbers while music is stopped. You'll end up replacing that cue point.
Hope that helped
Hope that helped
geposted Fri 24 Aug 07 @ 7:05 pm
You should be using the V4 manual for all the basic functions of V5 that didn't change from v4 to v5. I am still working on the FULL version guide for v5, soon maybe first part of next week.
Here is the V4 Guide -
http://www.virtualdj.com/support/VirtualDJ%204%20-%20User%20Guide.pdf
This is the V5 Updates Only Guide -
http://www.virtualdj.com/support/VDJ5-UserGuide_for_Updates.pdf
geposted Fri 24 Aug 07 @ 7:23 pm
From Keyboard shortcut, press ctrl -1 (same time)for cue 1, ctrl -2 for cue 2 and so on...
If u gonna go back to ur cues.. press alt -1 (same time)for cue 1 and so on..
geposted Fri 24 Aug 07 @ 8:27 pm
THANK YOU EVERYONE! I finally got this thing figured out. I got the old auto mix button working on the spacebar and I got the cues figured out. BTW, in the auto cue mode if it is set to enabled it takes you to all of the start cues that you set up. I know you guys probably knew that already but any newbies that see this it may be helpful. Thanks again, and give the new automix a chance, it works and NO SKIPPING!
Thanks VDJ,
Scott
Thanks VDJ,
Scott
geposted Sat 25 Aug 07 @ 2:26 am
