Forum: VirtualDJ Plugins
Topic: 'Alpha' Transition Usage
I couldn't find any documentation on this transition under support, and basically what I'm wondering is how do you use this plugin. Does it allow you to composite one video over another via a chroma or luma key? I've tried to set it so that it takes a particular colour (ie: blue) from a overlay video, and replaces it with the other players video like you would on a regular video mixer with a chroma key compositing.
And if this isn't what the alpha plugin is for, is there any other one that supports it? It would be great if it worked with live video as well however I have significant doubts about the stability of VJing in virtualDJ, and far too doubtful to even try it on a live show.
geposted Sat 25 Aug 07 @ 6:29 am
djcelPRO InfinityModeratorMember since 2004
This transition is for video which have a special alpha layer. These videos are very specific to VJing (used by Coldcut for example)
geposted Sat 25 Aug 07 @ 11:55 am
