Forum: Old versions
Topic: v4.3 crashes [SOLVED]
I have had it crash twice so far
once while I was gigin and I went to use the backspin effect......locked up with a loop of the cureent song
second was just a minute ago while just listening to a song....did same thing and I had to a hard reboot both times...
help please....I have a gig tonight and dont want this problem again
geposted Sat 25 Aug 07 @ 7:12 pm
what spec is your machine
what performance options do you have set?
Dell lappy dual core cpu, 1.5 gig ram......all performance setup including speedstep tweaker....I am using my onboard Sigmatel sound cards headphone jack.........has been working fine until I upgraded to v5
on vdj , go to options and performances and try setting fastest and autolatency
ill give that a try.....had it set to fastest already but not auto....hope that fixes it...let you know later tonight
could you look for crashguard.txt and post its contense here or send it to me via pm please
its located in C:/programfiles/virtualdj
here ya go
CRASHGUARD
date=708041400
version=4.3.r12
build=403
thread=Main
address=00442258
ins=8b1f891a
excode=c0000005 (0,31aa0d0)
CRASHGUARD
date=708181351
version=4.3.r12
build=403
thread=Main
address=004474cb
ins=8b928400
excode=c0000005 (0,84)
Have you tried to install v5.0 because your crashguard report concerns v4.3r12
You can now delete the file "crashguard report.txt"
You are reading the wrong file, go to D:\My Documents\VirtualDJ" and open "Crashguard report.txt" and post it here.
i totally uninstalled v4.3 then reinstalled...and it worked fine...although i did not try any of the effects was still worried it might happen again....ill guess i will just have to try it
