I have had it crash twice so far
once while I was gigin and I went to use the backspin effect......locked up with a loop of the cureent song
second was just a minute ago while just listening to a song....did same thing and I had to a hard reboot both times...
help please....I have a gig tonight and dont want this problem again
geposted Sat 25 Aug 07 @ 7:12 pm
what spec is your machine
what performance options do you have set?
geposted Sat 25 Aug 07 @ 11:43 pm
Dell lappy dual core cpu, 1.5 gig ram......all performance setup including speedstep tweaker....I am using my onboard Sigmatel sound cards headphone jack.........has been working fine until I upgraded to v5
geposted Sat 25 Aug 07 @ 11:59 pm
on vdj , go to options and performances and try setting fastest and autolatency
geposted Sun 26 Aug 07 @ 12:18 am
ill give that a try.....had it set to fastest already but not auto....hope that fixes it...let you know later tonight
geposted Sun 26 Aug 07 @ 1:53 am
could you look for crashguard.txt and post its contense here or send it to me via pm please
its located in C:/programfiles/virtualdj
geposted Sun 26 Aug 07 @ 2:09 am
here ya go
CRASHGUARD
date=708041400
version=4.3.r12
build=403
thread=Main
address=00442258
ins=8b1f891a
excode=c0000005 (0,31aa0d0)
CRASHGUARD
date=708181351
version=4.3.r12
build=403
thread=Main
address=004474cb
ins=8b928400
excode=c0000005 (0,84)
CRASHGUARD
date=708041400
version=4.3.r12
build=403
thread=Main
address=00442258
ins=8b1f891a
CRASHGUARD
date=708181351
version=4.3.r12
build=403
thread=Main
address=004474cb
ins=8b928400
geposted Sun 26 Aug 07 @ 4:29 am
Have you tried to install v5.0 because your crashguard report concerns v4.3r12
You can now delete the file "crashguard report.txt"
geposted Sun 26 Aug 07 @ 2:04 pm
You are reading the wrong file, go to D:\My Documents\VirtualDJ" and open "Crashguard report.txt" and post it here.
geposted Sun 26 Aug 07 @ 7:39 pm
i totally uninstalled v4.3 then reinstalled...and it worked fine...although i did not try any of the effects was still worried it might happen again....ill guess i will just have to try it
geposted Mon 27 Aug 07 @ 9:02 pm
