Forum: Old versions
Topic: Video effects not working
I cant seem to get most of my video effects to work with v4 or upgraded v5. Sideshow and negative work. Clipbank allows me to load videos but when activated, I only get screwing Hz lines.
I am do for an OS reload (XP Pro) so that may solve the problem.
Any known bugs?
geposted Sun 26 Aug 07 @ 10:37 pm
what video card do you have?
Compaq Laptop
Video and video transition works fine. Just the effects for when mp3's are playing.
This happened to me on a not so good computer with a crap video card, I couldnt get it to work for the life of me, so it may be your graphics card.
You Sonique library of effects may not be located in the appropriate place. When I initially loaded mine, they ended up one level further down the directory (folder) chain than VirtualDJ allows. I moved them up a level and all worked fine.
NickyB
