Forum: Old versions
Topic: Ampersan (&) issues
I've noticed a problem with the (&) symbol in the iTunes file name creating garbled text in the imported playlist. Here is an example:
8-03 Easy-Paula Deanda & Bow Wow.mp3
05 White & Nerdy (Parody of _Ridin'_.mp3
Some of the songs in the play list will not play that have the apersan in the file name. There is also info missing in the info box too...confusing!--
g
geposted Mon 27 Aug 07 @ 6:04 am
I use ampersand extensively in my tagging, and have no problems with VDJ reading them.
I see you mentioned iTunes, and I've read another post where that person also mentioned iTunes. I am wondering now, if it is with iTunes tagging features that are causing the problems.
Try using MP3Tag (http://www.mp3tag.de/en/)
First completely remove all tags from an affected file;
Second, enter the data manually;
Third, re-launch VDJ and see if the now manually edited file is having the same problems.
It is imperative that you remove all of the tags from the file before manually creating your own, as this will remove any iTunes tags that may be causing the problem.
Steve.
I think about a Itunes conflict too.
We will investigate
We will investigate
It does have something to do with the "&" symbol but not sure what. some work some don't. Quick cure is to use "and" instead of "&" in iTunes and search in VDJ for corrected song and drop back in play list and it works.....it's a round about way.--g
@ fotobro
Have you tried the method I mentioned above, to see if this eliminates the problem completely?
